Has anyone tried 5.4†tires from bourgault on a seedhawk? I have 10†spacing and struggle with dirt throwing especialy in softer soils or were it’s seen a cultivator. And the furrow gets pretty deep at times, therefore the seed is getting that much further into the cold ground
If I’d use a little wider tire and keep packing pressure higher would I not be able to cut back on both these problems?
Years we start early I think our crops struggle due to being to far in cold ground/ even if depth is right from bottom of furrow to seed
