1 - 20 of 72 Posts
Has anyone switch betwwen the 2, or ran them in the same field. Which one grows the better crop, goes through trash better? Anyone compared the mid row fert with the seedhawk. This year it was pretty easy to pick out the bourgault mid row fields for about 2 weeks at the end of june/ start of july, so just wondering if the seedhawk would be better?
Looks aren’t everything in June
Bourgault, Seedhawk And Seedmaster are all excellent drills Field finish is far surperior on Bourgault 99% of the time but finish doesn’t grow more grain. All 3 will have trash flow problems at times. MRBs hate wet loss stubble setting on mud and seedtwins make real nice mouse nests all over in fields that aren’t heavy harrowed enough.
One knock of most Seedtwins is there on 12in spaceing and that’s a little wide to Max out some cereal yields in my opinion and experience.
Buy a drill that you can get excellent service from local dealer. If I was buying new today and money wasn’t a option it would be a seedhawk drill on a Deere C850 tank. Not knocking the Seedtwin tanks but there far from Bourgault and Deere quality, support and ease of use.
I am also curious about new seedhawks. I’ve read through all the old threads on here and it seems like they were working out bugs progressively every year after after introducing the new models around 2016. Have they got them working smoothly consistently now? Ie meter motors and iPad disconnects?
Dumbfarmer I also like the look of the C850, but am not a fan of their sectional control system grinding grain. Have you used one? How was your experience?
One factor that has us starting to lean towards a complete seedhawk unit is their claim of less hydraulic capacity needs. If anyone has any experience running one with a lower flow tractor(~50gal/min) I would be interested in hearing your experience too.
I had a BG PHD and switched to Twin Wing Seedhawk. Just got tired of seeing the seed row N deficient until time for roots to actually reach the MRB. Never made sense to me to place N at the absolute furthest position away from the seed you could put it. With that said, the Seedhawk comes out of the gate much faster, and lusher, but I was never able to prove an end yield difference.
My Seedhawk drill is on a Bourgault 950 Tank though. When switching over I demoed the Seedhawk tank and wasn't able to load it from a superbee easily with only 1 guy in the field (me). The ease of use on the BG tanks is second to none, and unbeatable in my opinion.
Distribution is likely better with Seedhawk tanks. BG has had issues with high rates in the past on units since they switched to putting primary distribution on the tank rather than the drill. The last couple years, they have been working to try and solve this problem and a modified primary distribution system is now available. I can say that my fertilizer dist. has been upgrade and performs much better than the old system. Seed will be done this coming spring as well.
Have to also say that I like the twin wing a little better than single side band. Where I'm at, a little more disturbance blackens it up a touch and seems to move a little more straw out of the seed row. It is rough though when crossing it. BG is a better field finish for sure, but looks don't necessary pay the bills either.
Haven’t used a c850 yet but my dealer tells me seed grinding is a non issue with some kit installed in Canola meters.
My seedhawk dealer still admits there’s challenges on new tanks and software
No one is getting any younger on my farm and safety is only becoming a bigger concern. No way am I paying 100s of thousands for air tanks that aren’t user friendly and that a 8yr old or 80yr old can use and climb multiple times and feel safe. Deere and Bourgault seem to have the safe and easy thing figured out better then the rest.
Admittedly we have only started researching seed hawks a couple weeks ago and haven’t actually climbed one. Is the ladder and walk way poor/dangerous?
You’re right, useability is very important, and Deere has some of the most intuitive software on the market.
The pictures and videos I’ve seen of seed hawks icon looks fairly slick, and well laid out. I wonder how it is to use?
I don’t want to start a pissing contest but why would you see the row be deficient of fert in the seed row. What is your fert system ? Typically the mid rows are used for nitrogen and the plant doesn’t really use until it is a few weeks emerged. Pho’s should be placed with the seed as it does not disperse in the soil readily . Are you using a blend and putting a percentage down the mid rows and a smaller percentage down with the seed? Perhaps the seed row is lacking starter fertilizer?...... just curious as I have heard this before about mid row banding . Yes we do have a paralink and I have not seen this effect ....... if one fert system is using a blend then the pho’s used is probably from the previous year ....... can someone enlighten me on this ( plants stranded too far from mid row) ........ I could also see some of this happening if it’s dry as **** out but if it’s that dry your a long ways up **** creek lol...... the mid rows are extra maintenance but aren’t too bad and they do cut the straw to help trash clearance
You must have the only honest seedhawk dealer on the planet, I know my local dealer doesn't even sell the seed hawk tanks anymore, however the seed hawk rep always tells me the tanks are almost perfect and they never have issues.:rolleyes:
After climbing up the Deere C850 tank at the latest show I'm not really convinced how safe that staircase is. The steps are narrow and have large gaps plus everything shakes and wobbles.
For anyone that likes the seed hawk metering I would take a good look at the CNH/Flexi coil tanks, very similar meter system that has very few bugs and the support of a large company behind it.
Yes plant stranded from N partially. I refer to seed row as the growing plant row. Every year you would see a lighter color, spindlier plant prior to, and up to, certain points at or following weed spray timing. ie. It usually took that long for roots to tap into the majority of nitrogen placement (midrow), as you can only put a portion down in the seed row safely. Once roots got there, darkened right up and off to the races you would go. Timing slightly variable, but if you watched closely you could see which rows had found N, and which ones hadn't by color of the plant.
Doesn't happen when majority of Nitrogen is placed closer to seed ie. Non-Midrow. Most notable in wheat and barley. Noticeable in normal precipitation years, not a drier than **** area here.
Was putting a portion of same blend down seed row and midrow, 20% in seed row of an actual 125N 50P blend, rest in mid row.
I do agree MidRow help with trash clearance. Negatives IMO are maintenance, placement of N, and Huge Cost.
No love for the JD/consevapac drill?
They seem to grow as good or better crop as any.
Other than the width we want don’t really have a high float option.
I sure don’t see a huge variance between runs when the crop comes up. That’s pretty low on my list of improvements.
Secondary hose that will make a whole season is right up there. Or if I could dream a little 2 seasons!
Ran seedmaster, than a few years of seedmaster and bourgault and now just bourgault. If you fertilize any amount be careful with the seedtwins burning canola seed, have seen it lots. Not a lot of separation, especially if you have hills and the drill drafts a lot. For the most part though either system will grow you a good crop.
Discussion Starter #14
I really like the jd/ conserva pac but i think deere took a big dump on the average farmer. They made one new model so big and heavy (way heavier than it needs to be) that you pretty much need the biggest tractor with tractor on the market to pull it. I think they really screwed themselves, the great big guys won't buy them because they are too complicated for (meat in the seat type of guys to run). Its just too much $ for a average guy to want to put out at one, tractor and drill. Why can't they take 10 off the wings, why is it soooooo heavy.
The bourgault fields that look like they struggled for a bit were all 12 inch spacing. I see bourgault uses 10 inch for all there study's, propaganda. Maybe that extra couple inches is a little to much for the fert to move.
Spacing wise i switched from paired row to side band on my 12 inch spaced morris contour this year and i think the wheat was definitely not as good but the canola was no change.
No one has mentioned that Bourgualt has the worst seed and fertilizer distribution on the market but you won't hear that from them!
Have you ever used a newer Bourgault? Never had or seen a problem yet over 13yrs and 3 different carts.
No way I’ll of us with Bourgault carts would put up with poor distribution and we should all be seeing striping if it was a problem
You might be kind of boxing yourself in if 100% of the nitrogen is always going down the mid row branders and no percentage of other nutrients are placed over there in order to make room for some possible nitrogen in the seed row, if your climatic conditions required that close by nitrogen.
From what I’ve seen, blends are a good option in every tank. There doesn’t appear to be significant need, right around here, for additional nitrogen near or in the seed row on 10” spacings, if there was, we could add some nitrogen to seed row blends going into farm storage.
Bourgault’s can use the same primary hose as any other brand, I expect the reason the hose doesn’t last as long in time is because in some instances they have done more acres in a season. A disk drill clobbering the acres can certainly wear them away.
Do a search online about the studies that were done on air cart distribution, and that was done by a 3rd party. There system is about the same as concord used years ago, which wasn't bad for its time.
Exactly which studies are you talking about? I believe MB pulse paid PAMI to do one in 2018 on Bourgault and Deere and Bourgault had a CV of around 11%
11% CV isn’t bad for any air system.
howardgroupinc.com or search accurate metering but poor distribution
I owned a 7950 on a 66' drill and it wasn't perfect but not as bad as some of those studies suggest. There is one particular study that is pretty much bogus IMO, can't find it at the moment but it has been posted on this site before.
What I really don't like about the Bourgault delivery system is the archaic metering and the fact everything hits another manifold under the full blast of the fan. There is more grain damage and it is very inefficient when pushing high rates of product. I like the rest of the tank a lot though and have been thinking about all of the aftermarket metering bodies around that are made of stainless such as this: https://romafa.com/
I wonder if a guy could modify a BG tank or if they would sell one less the metering equipment. Main concern would be how is the thing unloaded? Probably not room for it to swing away under there like on a CNH tank, if I understand correctly the JD dumps through the bottom?
As to the original question if there is cereals involved then narrower rows will generally be better, canola not as important. Seems a fair number of Seedhawk on 12" and with BG if you are doing midrow then 10" is definitely better because of need to throw dirt over fert band. I would lean BG with some minor reservations, but clearly nothing is perfect and every year is different.....how's that for a non answer!:wink:
1 - 20 of 72 Posts
