I have a 316 head on a M2 that will not feed. The reel and conveyor are rotating, however, the beans stack up and try to feed all at once clogging the header up. I had this problem last year thinking it was due to short beans, but my beans this year are 4' tall. They wedge between the conveyor and the rear feather sheets. Ideas?
i had that problem when my header height controll was messed up. the header wasn't going down enough and the beans would stack up on the hump of the rear feather sheet. another potential problem could be reel fingers cut off or reel too far foward
Make sure reel is as far down and as far back as it can be. On our 320 we put a piece of flexible hose (I think 2.5") right behind the cutter bar. Helps keep the stalks up and puts them into the table auger.
My 525 header had corrugated black plastic hose on it right behind the cutter bar too. It was held in by conduit clamps, it really does seem to help except in beans following wheat with stubble, it's just a place for it to pile up then. Another possibility is are you missing auger fingers? I lost a few and it did seem to make a big difference in how smoothly it fed
Just a thought, but what's the condition of the flighting on the table conveyor? You might want to see if the edge is wore, if so take an angle grinder and square the edge back up. It may help grab and pull the material in before it can mound up and make a slug.
Yes, there is provision for both fore/aft and height adjustment. If you have a manual it's on pages D9 and D10, at least in my book. I don't know how much adjustment is there, but it may be worth a look.
Best of luck, Tom K.
