Finished corn, now I want to setup for max performance in soybeans. Replacing the four front round bars with four large wires. Replacing the eight straight bars in the separation area with rasp bars and spikes. Vanes are in the slow position over front concaves. Mid position over rear. Should I replace the skip wires with round bars in the separation area? Any suggestions?
Large wire in the front and skips in the back worked better than round bars in the back. Rounds in the rear increased the trash on the decks. Due to tough pods had to run rotor higher than normal 730 + and little tighter than normal "2". Vanes in middle all the way across with no straights, 8 spikes in the rear, fan @ 960, top 1-5/8 @ 16 bottom 1-1/8 @ 12 .With 35ft draper, 4.0 mph (head started to cut ragged above that speed), 50+ bu/acre dry, Zero dockage at the elevator. Next to no tailings.
Thanks, Started Wed. Large in front, Skips in back.8 straights left in.4 spikes in rear. Vanes slow over concaves, Mid over separation with very back two in fast. Fan 900, Pre cleaner one notch open, 16 top,12 bottom, concaves 6. 35' draper, 4-4.5 mph. [ over that ragged cut] 50-65 BPA.Doing a good job, plenty of power. Added a adjustable deflector instead of fingers. Doing a better job of spreading. [ no windows of chaff]
Started harvesting soybeans that have been sprayed with fungicide. Having trouble with Green stems and pods. Had to speed the rotor to 750, closed to 2, running a lot of tailings. Top sieve 15 , bottom 12,[ if close to 11 too much tailings. Fan 850-900. Need to do something to improve sample, they are seed beans , about 800 acres of them.
