1 - 20 of 25 Posts
It would be nice to have a setting thread stickied at the top with setting guys use for all the major crops. Just be a quick way to reference what works best in the real world other then what the book says. Sadly I have nothing to offer as this is the first season with it and I am flying in the dark here.
I have been using the setting for malt in cemo's auto, is that the right setting for barley as there are 3 or 4 choices, us barley, winter barley, malt, or spring barley.
Can't help you with barley, we've never done it with the Lexion but just finished our wheat tonight so I'll kick it off with my HRSW settings on a 590;
Concave 7
Cyl 900-950
Rotors 1000, or fast as possible
Rotor covers all open
Jetstream Fan 1250
Chaffer 15
Sieve 5
This gives us about 20 ac/hr average over 4 seasons, with .3-.4% losses and 1% dockage
As far as settings go you may get all kinds of opinions. Everyone will have a setting that works for them and not others. I find the fold out card that comes with the machine is a good starting point then tweak from there.
If you have a Cemos supported crop, let Cemos auto do it. Cemos does a fantastic job of cleaning and seperation so just main cylinder speed and concave clearence are important to you.
For wheat and durum you will need keystock APS grates, APS closed, ITS (intensive threshing segments) installed. I run 3 concave filler plates in and may install a 4th one as there can be too many white caps when conditions get tough in the evenings.
And feed the beast, she is hungry.
Bdpolar are you getting any cracks with your cylinder speed at 900? We have been running around 720 rpm in durum to keep from cracking and have been running the fan at 1370-1430 to help blow out fuzarium kernels. The rest of our setting are similar to yours. We run the smooth slotted small grains APS grates with the grates open and the Intensive threshing segments in for all crops. I want to take as much grain as possible out of the APS.
How much returns are you guys allowing I have a small amount of cracking and whitecaps and can't determine if i'm cracking in the threshing or the return , return is running quite high
Have never done durum so not sure how it compares to thresh out. We run the small smooth grates but with them always closed, find that we get more unthreshed, broken heads when open. Ran ITS a couple of times in the 6 years I think, don't even know where they are anymore. This gives us about 1/3 of returns on the monitor.
Yeah we are for sure getting some cracks but all our wheat is cleaned for certified seed so we would rather trade a few smashed for high dockage.
Ebear how much grain is in the return? Cylinder speed is what often causes cracks.
looks to be mostly grain but its difficult to tell need to either kill stop it or get a sample I feel that its more likely its cracking in the return but was wondering at what level everyone runs the monitor , or how much actual returns of any kind you have . cyl 850, concave 8, fan 1350, top 13 bottom 8
If you can't see the center of the auger shaft, return is excessive IMO. Disengage seperater when you turn machine around. This will give you a good visual on what is in the return.
Ebear on some days and conditions there will be a lot of return. If there is grain in the return you need to open up the bottom sieve. A TM6 top sieve helps reduce the return. When my return symbol starts blinking to warn the return is getting high on my 590r then I try to make changes to reduce the return. The other thing you can do is put in some rotor covers if there is not too much rotor loss.
Yes easy threshing 36ft at 4.5-5 mph 50b/acre but whitecaps and cracking just trying to determine where the cracking is occurring only showing 20% load so I am coming to the conclusion that I'm not doing enough in the cyl some are running 6 mil and a friend of my ( 480) is at 3mil and having trouble this year at his normal settings
Excellent idea. Tread Stickied.
590r with 1050 Maxflex settings
Ill start with pea settings then list wheat settings for this year. Ill add the header settings we used as well.
Pea settings
Header Maxflex 1050
AHC sensitivity set at 80-85
Reel all the way back towards auger. Teeth settings was 1 hole forward past center or third from all the way forward.
Reel speed set to auto at -.8 to +1.2 when traveling at faster speeds we used the -.8 to keep the shelled peas from getting tossed by the reel.
Reel height as needed.
Auger settings was 12 mill of the floor.
Auger fingers were set to aggressive, top hole on each side of header for long straw settings. This help to keep peas from going over the auger and greatly improve feeding.
HP settings was about 4 to 6 degrees forward. If you have flat on the ground peas this will need to be more aggressive.
These settings kept header loss down with great feeding.
Combine settings 590R
Sunny brook concave and cylinder "Goose Feet"
Concave have large round bar box sections in front and a wheat box section in second row then large round bar box section in remainder. This configuration provided us with the least splits.
Concave clearance was set between 10 to 15.
Cylinder speed was down to 260 RPM
APS grates 12 mil smooth slots. APS doors/flaps open
Rotors RPM around 400
TM6 top sieve 18-20
Bottom regular sieve around 8-10
Fan speed this year due to high bushel weight around 1470 RPM.
These settings provided us with the best pea sample with around 2 to 2.5% splits.
Wheat settings
Just getting started in wheat so things could change but this is what we are using so far.
Header settings set the same as peas with the exception of the auger fingers they are set 2 hole from the bottom.
AHC set at 65
Combine settings
Concave have filler bars installed in front large round bar box then a wheat box section in second row then large round bar box section in remainder.
Concave clearance set at 6
Cylinder speed at 700 - 800 rpm depending on conditions that day.
APS grates 5 mill keystock grates for wheat. APS doors/flaps open
Rotors around 850 RPM.
TM6 sieve open 15
Bottom regular sieve opened 4 to 5 depends on kernel size and return level.
Fan speed about 1330 RPM. Wheat has high bushel weight also.
So far these settings have provide us with a good sample and acceptable whitecap levels for the year as we have a huge range of yield difference in every field so far.
Will add more settings for fabbas and Canola when we get rolling in them.
Canola Settings Straight cut
Header 1050 maxflex
AHC setting 65
Auger fingers in 2 hole from top
Reel speed auto set a 0
Combine
Concave clearance set at 12
Cylinder speed at 280 - 600 rpm low speed drive. (Yes slow due to high amount of green plant material this year. helps to not chop up so much and keep it out of the hopper )
APS grates 10 mill grates for peas. APS doors/flaps open
Rotors around 670 RPM.
TM6 sieve open 13
Bottom regular sieve opened 3 to 4 depends on return level.
Fan speed about 1040-1070 RPM.
So far these settings have provide us with a good clean sample.
A C and P from the other sermon, I mean thread
I never change any components between crops using the large oval pressed metal APS concaves, never intensive threshing plates, Sunnybrook (SB)concave and cylinder "Goose Feet" equipped unit.
I've never been able the covince myself changing anything resulted in a any performance change justifying the trouble.
I choose to just do the best job I can with what I have.
So, let's talk settings with said setup, perhaps I'm pretty staid in my 8th season but it works for me, by crop:
Wheat-APS concave closed, concave 7mm max up, cylinder as fast as possible up to cracking but often as fast as it can run. Cylinder always run in all crops just at or below cracking, I wish Claas would get the quality cam to NA!
Peas-APS open, 10mm, 300 to 450 (low speed drive) upper and lower sieve both max 20mm open, fan 1200 to 1500.
Barley- APS open, 10mm, 800 ish
Canola- Aps sometimes open, sometimes closed, 20mm, 550 to 700 and here's the biggie in canola, 8 total rotor sections manually covered.
Cruise pilot used 99+% of the time
CEMOS Automatic for everything except peas, not a supported crop nor would there be any advantage to be.
I suspect my concave clearances are tighter than most run, I thank the SB setup for that.
Thus ends the Minister Don's sermon!
Conditions can vary wildly for even one producer let alone the diversified group here, your conditions vary, you set for them, just thought I'd throw out my general specs.
I definitely don't like doing anything that takes more power (I also run chopper stationary knife bar completely out) or is more likely to plug anything!:38:
Back in the combine today in canola, here's what I use in dry 30' swaths:
Cyl. 600
Fan. 900
Con. 30
Chaffer 9
Sieve 4
Rotor 600
Aps doors open
Electric rotor covers closed
When it gets tough at night or starting in the morning I'll get the Cyl up to 800 and rotors to 900 depending on power use and losses. If it gets super dry I'll get them both down to 450 for sieve loss.
Anybody have really dry corn settings for750tt 250 bushel ac 12.5%
Feederhouse - depends on ground speed, try to run it below cylinder speed if possible, otherwise as low as you can for the target ground speed
APS Grates - Round bar preferred, or std corn grates are okay
Dis-awning plates open
Cylinder - about 300 in dry corn
Concaves - if N18 (large wire w/ keystock) then run 2-3mm over the cob diameter,
- If round bar run at the cob diameter, maybe 1-2mm over in dry corn
Rotors - Slow as possible in corn, always. If seeing rotor loss then slow down/open up things in the CYLINDER.
For cleaning, I start my fan low (about 1050) and loss sensor sensitivity at 80 and set my sieves first.
Top Sieve - 18 to start, adjust down to resolve MOG in tank. If it is a deep-tooth sieve I have run as low as 6
Bottom Sieve - Start at 23 or so, and adjust down. Want to run as tight as possible without creating much return volume. Running trash through the return will only limit the machines capacity.
After the sieves are set, turn the fan up until the sieve loss starts to rise, then turn back to the point just before that. In dry corn 1050-1100 fan should be plenty but it can help sample quality if you can increase it without increasing sieve loss.
I ran in 230bu 15% corn with a 740tt and 12 row. My settings were 360Feederhouse 320cylinder 28concave 360rotor 14topsieve 17bottomsieve 1080fan. I could run as fast as 6mph but I would get a little bit of stalk pieces in the tank from the header. Slowing down to 4.5-5mph the sample was flawless
Mustard
Would any of you share your settings for your mustard crop? Mustard is dry 6.7% but stalks are green and wet. I'm really overloading the top sieve right now and it will stop the chaff spreader. This Is a 750 lexion
1 - 20 of 25 Posts
