We are running our cvs 32 on a new to us 9870 this year with a straw chopper. How are guys running their choppers with a stripper header? I was thinking low speed with the stationary knives out. Any info is appreciated.
You might already know, but just remember you HAVE to engage your feederhouse before the separator on a JOHN DEERE when useing a stripper otherwise it will break the sheer bolt. Just another reason to have your feed acc and chopper on slow ( and rotor as slow as losses or sample will allow) as it helps reduces the load on the separator clutch and gear case upon startup.We are running our cvs 32 on a new to us 9870
I didn't know this. I ran it last year on our 9760 and never had a problem. However I'll watch this on the 9870. Will a slower feed accel be a problem in 90bu wheat? I've always run it fast in the past. Never thought about it I guess.You might already know, but just remember you HAVE to engage your feederhouse before the separator on a JOHN DEERE when useing a stripper otherwise it will break the sheer bolt. Just another reason to have your feed acc and chopper on slow ( and rotor as slow as losses or sample will allow) as it helps reduces the load on the separator clutch and gear case upon startup.
