We are installing the sunnybrook sweep kit on our S 67. While I have the cylinder out is there anything else we should do? We run Corn/Beans/strippered wheat. We are also removing the reverse bars in the 2 left side discharge rows that were factory installed.
Couple tips. Did you weigh the bars you took off and match weight to new bar as close as possible? I usually glue needed weight to pocket under bar or grind away needed material from same area. Also weight of sweep needs to be added directly across from sweep in same circle where you added sweep. If only three mount plates around rotor you would have to mount ever third way around. We did not have to do this with old small diameter rotors but am finding to static balance these new rotor we need to pay attention to this. If you are taking your rotor in to be spun balanced you may not need to worry as much
