I think if you look at it year to year there will be small differences but in the long term if p levels continue to drop that is going to become the limiting factor in yields. I am looking at this as a way to be able to consistently add more than removal rates and be. Lose to the root regardless of dryness without the toxicity in the row
I used to be of the same opinion, but lately I feel that way of thinking is wrong. Most of the data has been coming out of Europe or the US where their soils are much older and also in a thawed state year round.
In the prairies the articles I have read say we have a HUGE pool of phosphate tied up in the ground (for most soil types, there might be fringe exceptions). The problem is the phosphate is tied up in tight bonds with other minerals.
Applying very high rates of 11-52 gets slightly higher rates to the plants, but does very little to the overall total (peeing in an Olympic swimming pool).
Doing things to increase the plant availability from the huge bonded phosphate pool is where the future is headed in my opinion.
Cover crops are already showing a benefit for increased P availability, but doubtful they will work for most of the Canadian prairies as our growing season is too short.
I floated on 300 lbs/ac of 11-52 on 40 ac blocks in 3 fields and have been using normal 11-52 rates during seeding and have seen no yield response yet to the floated areas over the last 4 years. Recommend you try some test areas. My soil test P is usually low on soil tests, even in the floated areas.
A lot of P can be put down the MRB’s if just looking to boost rates. A lot can be put with the seed in moist clay soils as well.
If you do decide to go the sideband route, it will work in most soils with “V” packers, but not as consistent depth. I have tried 2”, 1” and 3/4” bourgault tips with V packers and was a little disappointed with the 2” and V packers. Tried a few round packers and the 2” worked quite well.
