Traded 8010 for 8120 and am wondering if the 20 series is updated so you can turn on the side lights with the turn signal switch. I had to run a seperate switch on the 10 and just wanting to know if I need to pull the switch and wires and install it on the 20.
You can with the turn signal with the newer software. Left Right Left Center, should turn them on. For the 10 series with older software I just took out the hazard fuse and left the turn signal to the right.
Have to look for sure but believe I ran a wire from the turn signal fuse to a switch then back to fuse. When in field turn the turn signal left and then shut off the switch i install and it shuts off the turn signals. When roading just turn the switch back on. I also have just pulled out the turn signal fuse when in field and stuck it back in when roading.
Soo will an 09 8120 have new enough software in it? This just seems silly that they did this anyway!!! Has to be developed by the same guy that built the grain saver on the unload!! Update was really nice if you wanted a shorter auger that dribbled corn just like the one before it!!!
