Can you use a small wire concave on a 9770 to cut milo? Only need to cut 50 acres. If you cant why?
D dac492 · Registered Joined Jul 1, 2010 · 1 Posts Discussion Starter • #1 • Jul 1, 2010 Can you use a small wire concave on a 9770 to cut milo? Only need to cut 50 acres. If you cant why?
Bundy Bear · Registered Joined Sep 19, 2008 · 1,244 Posts #2 • Jul 1, 2010 you can but your capacity is severely limited. for 50 acres just go for it.
Alex Ryan · Registered Joined May 11, 2010 · 723 Posts #3 • Jul 3, 2010 pull every other wire out of them, then you have a large wire concave for the 50 acres and it's really easy to do.
dragoguy · Registered Joined Oct 10, 2008 · 961 Posts #4 • Jul 4, 2010 yep. pullin everyother wire works slick.
