It will still take the stumps out on the big trees And what sheers off will rot out. Still a good idea to float and harrow on your first crop by the next crop go in with the drill no problem. The Kello's we use aren't heavy heavy, pull 32ft with 400HP, I'd think anything with notched blades would work just might do a few more passes, or add some weight, or if it won't cut and has wings run with wings up first pass. The cats are the efficient part of clearing the hoes take a lot of time. I wouldn't say they are cheaper to run, cheaper on fuel and purchase price is about it, a final drive or hydraulic pump etc is still all expensive. We run new hoes and 10-15 year old cats and neither one leaves us sitting much. You can push and pile an acre in heavy bush in 2 hours with a D7. fuel cost is probably 50 an acre, maintenance long term 10-15 an acre, operator 40 an acre, purchase price varies. If I buy a 1997 D7R right now for 125-175000 I'd expect to run it 5 years minimum and within those costs, and clean 3000 acres with that machine in that time. So total cost would be 155 an acre. Hiring it at 150 an hour would cost 300+. So you can make your own numbers based on how hard you run it, purchase price etc.... A cat and a hoe go hand in hand, choosing one or the other id get the hoe first, if your serious about knocking down bush buy both, no better investment than making farmland. Said and done we can crop it for 350 bucks give or take.
If you don't fix yourself maintenance will be higher. I just did a torque in one for 2000, a reman was 8000 from cat just parts, it pays to look around.
