I used to think that a lot of the amounts needed from the fertilizer tests were high. Gone to a few canola production workshops lately and I discovered that the recommendations from the fertilizer tests were fairly consistent with the canola production workshop numbers.
When I looked at my old soil tests and then added what I applied and estimated the mineralization from my organic matter level it was almost exactly the bushels of canola that I actually got in the fall. For example the canola workshop said it takes something like 3.2 lbs of N to grow a bushel of canola. If my soil test said I had 20 lbs of N and I applied 100 lbs of N and then added 20 lbs of N from mineralization (4% organic matter x 5 lbs N per %) I got a total N of 140 for that crop. That should give me 44 bushels of canola (140N/3.2 lbsN per bushel). Some years you will get more mineralization and some less.
I found when I went back and looked at the soil tests, looked in my notes at what I applied for N and my crop insurance records for yield, I was surprized at how close the actual yield was to the N I provided for that crop. In my case I found that I was drastically under fertilizing my canola.
Not sure how accurate the soil tests are for P, K and S though. I try to replace my P and S levels according to the yield estimate that I am using and I have high K levels in my soil. I do not think that any fertilizer seller is doing soil tests(with some of
these kits) with the idea of upselling you more fertilizer.
With most fertilizing equipment today it is very easy to up the rate by 50% on a pass or 2 in a few fields and see if there is a difference. Allows you to test fertilizer rates that you don't think will work in a very easy and affordable way. Also gives you some safety just in case your seeding system cant handle the higher rates and you get seed injury or hoses plugging, it is only confined to a pass or 2.
