Had the chance to run an SP365F new holland front boom last week, here are a list of pros and cons in my opinion from my experience in this machine. I had the chance to spray out a few tanks doing fungicide in a relatively hilly peice. Was a 2013 equipped with an intelliview 4
Pros
- The front boom, I love the fact that I can see every nozzle
- Rides very smooth, better than my case over the same terrain I sprayed 2 weeks earlier with the case
- Visibility because it's so high
- Big Tank, I liked the 1600 gallon tank especially being able to do a whole 1/4 with a fill at 10 gal
-engine accessability
Cons
- Its very underpowered, even with only 6 or 800 gallons in tank
- The boom height control worked very well but the booms flap around like its a seagull, they flex to much IMO
- I hate having to walk to the back of the machine all the time to get in
-The seat and the hydro handle suck
- boom tip travel isn't very good, maybe it was the way it was set up but it didnt have much tip travel
-If it wasn't widened out to full axle width it was scary as **** on sidehills, I didnt extend the axles because I wanted to run in the same tracks I made with my sprayer before
-I am so used to AIM command I have a hard time accepting the way the rate controller works on a conventional machine, especially when climbing a hill with this gutless wonder and it bogging down to 7 or 8 miles per hour causing the nozzles to drop pressure and dribble like a dink when you finish taking a piss
- The gear selection, I am so used to the infinite speed control dial on the case that when I got in this thing I had a hard time adjusting to the fact that I had to pull back and vary my speed with the hydro handle
- The fuel tank is in a really stupid place
I know some of these things can most likely be adjusted but , this was my opinion based on how this unit was set up, it had probably 8-10 demos before me. By the time I finished my demo it was sold anyway
Pros
Cons
