1 - 12 of 12 Posts
Discussion Starter · #2 ·
We will run 40ft swathers only this coming season,so i need the shortest possible cut and widest possible spread...Had the stationary knives all the way in last season,worked awesome when it was dry,but when it gets tough i would like to get a better cut.The Deere chopper is already lightyears ahead compared to the 8010s we used last year,i still can see every pass of the 8010s during seeding,even after a pass with the heavy harrow.I am glad we run only Deeres this year.
I wouldn't speed any chopper up to a higher speed than it's designed for. You're just asking for trouble.
The control bar is a bar that fastens to the chopper floor just far enough back to not get hit by the rotor but to slow down material flow enough to let it get recut somewhat. The idea is to hold material in the rotor a bit longer.
The problem I have with the control bar is power consumption. Deere choppers are already fairly inefficient and take alot of power to do the job and the bar only makes the situation worse. Next week I am converting a 9860 Premuim to a Redekop rotor because of the horrendous power usage the Deere rotor requires. It causes the 9860 to have no more capacity than a 9760.
Thanks for your input greentech.How much is that redekop rotor?We have the powercast tailboard on the 9870 that we ran last year,it tends to spread to much straw to the very outside in tough conditions,the spread pattern is not 100% even.
Redekop doesn't have a rotor to fit a 70 series yet simply because the 70 series chopper is very close to being a copy of the Redekop MAV. After looking at the parts catalog I realized that the only difference is that there are paddled knives all the way across the Deere rotor. If you could change these knives to a straight blade you would get a finer chop with less power consumption but I don't see a straight blade option like the old rotors had.
You could probably bolt on a complete MAV chopper but that would run you at least 8 grand.
I to think you should be able to speed up the chopper a bit even 10% would make a diff.I believe the standard chopper is 2700 rpm and the one on the premium combine is 3500 rpm am going to check it out and see what the diff is.
1 - 12 of 12 Posts
