I've seen it before on eBay but the $35 delivery fee scarier me a bit. I've seen on YouTube guys making their own from old cans. Looks a bit unsafe but I might give it a go.
Nice. How much did the strip lights cost you for the whole 100ft and does it hold up to the stress of spraying. Did you zip tie it along. Any pics available.I have LED strip lighting along my entire 100 foot of boom on my jd 4830 underneath to light up the actual spray so I can see if blocked or not. also have a small LED flood light on each end of the boom to see fence lines and night.
Thanks Dak. Hope to be doing a lot of night spraying on our cotton this season in between other operations.Hi there Gav, we have pecil beams mounted on our boom & think there great, they are on centre section slightly below nozzels & just in front of
them. They show up all nozzels well!
In the days of spraying cotton they were essiential, you could be 1 km away & see that they were all going.![]()
Hope this helps.
We have the sprayer airbags running of the tractor brake line and a hose reel on order to be fitted to it soon. I think this is the best option as every time I try to use an aerosol can its empty.I've seen it before on eBay but the $35 delivery fee scarier me a bit. I've seen on YouTube guys making their own from old cans. Looks a bit unsafe but I might give it a go.
I bought 60 (i think) led modules that are 100 lumen each, they come wired together in a big chain (you'll have to cut the and space them). You can only run them for 20 metres max, so i've got left and right boom 15m each, wired on separate relay, switch and fuses. took a long time to set up but, pretty happy with it. cost just under $400 vs $2,100 for the AppliMax Spray Nozzle Lights, so saved quite a bit.Nice. How much did the strip lights cost you for the whole 100ft and does it hold up to the stress of spraying. Did you zip tie it along. Any pics available.
Thanks.
