1 - 11 of 11 Posts
I have volunteers in my fields that I didn't seed this year.I'm assuming I should add buctril m with my glyphosate when I do my burn-off on my summerfallow fields. What is this going to cost me per acre now to get rid of it ? Thanks for any info
I used Heat/glyphos ate tank mix.....pretty much a failure on the volunteer canola. It burned the top of the canola off but there are still green leaves . Have a bit of a mess not sure what to do with.
Heat is a contact herbicide, sounds like you didn't use enough water for proper coverage. IMO it works very well. Have to use a pretty high rate though to get residual. Prepass is a cheap good option with residual, watch crop restrictions though. Otherwise 24d or MCPA is good.
1 - 11 of 11 Posts
