I was using my Steiger Pt 225 to run anhydrous today.
I was in 13th gear - about 6.3 MPH.
The first 100 acres was fine, but then I got into some soft dirt.
I wasn't stuck at all, but the cultivator pulled into the ground a bit. The tractor started slowing down, and then just stopped moving. The engine didn't rev up, the tires didn't spin.
I wasn't stuck.
The trans pressure light and buzzer came on.
I put in the clutch and lifted the cultivator.
I released the clutch and the tractor very slowly moved forward and slowly gained speed until it was back to 6.2 MPH.
I put the cultivator in the ground and kept going.
It did this two more times.
Trans fluid level is fine.
I dropped into 12th gear and finished off the field without this issue happening again.
When I start out in a high gear, there is a bit of a rattle or chatter until the tractor is up to speed - then it's fine.
Is this tractor going to need a clutch, or is it just out of adjustment?
I will be crawling under it tomorrow morning to pull off the inspection cover....
Thanks for any thoughts/opinions...
It took 6 turns on the adjusting ring to get it back to spec.
There was a thin film of sludge inside the inspection cover consisting of some oil and dirt.
Assuming that the rear main seal must be leaking a touch....or is that normal?
Always seem to be slight trace of oil, trans seal can leak there too but if the rear mains goes you will lose a clutch quick and damage the flywheel as well with slippage , which matches your first post
