Blocks are in the grain position. Close to the floor. Auger has paddles not fingers. For the steering, flipped the tires so the dished in, moved the axle out so the was 3 holes showing, moved the rams out to as far as they could, adjusted ball joint so there was 1 1/2 of thread showing on each end of the ram, and removed the wheel stop bolt. Turns awesome now.
