Hello everyone,
With the late harvest this year we have seen many STS combines in the area have cleaning fan issues. There seems to be a buildup of frozen material directly behind the front edge of the precleaner. As the precleaner shakes back and forth it pushes against this material buildup until it causes the housing to push into the cleaning fan, blowing everything up. This is true for all STS machines, including the S-series machines. The only way to see this buildup is to take out the sieve and chaffer and look under the shoe augers. Because of this our local dealer is drilling 2" inspection holes on the side of the machines to inspect and clean out the material.
Has anyone else seen this issue before and have any words of advice to fix the buildup problem? I would say that over half of the STS machines in our area have had this issue. Most of the time it takes out a lot of shrouds, the fan and possibly the sieves and costs up to $10,000 in repairs. If someone hears ticking in the fan they can catch it before the grenade goes off, but that doesn't happen very often.
I look forward to any insight on this.
Thank you!
Thank you!
