1 - 2 of 2 Posts
got a stx 500 that the engine quits runs good, just stop with engine fault
had case and cummins come out-case said cummins problem, cummins say case problem
changed relay under batteries- still quits
computer shows power failure
going to change batteries, battery cables, check ground straps today
what else could cause this problem?
dangerous tractor as no brakes when it quits, case said shut off key to activate parking brake
Are you getting and codes, if so can you list them, agree with checking all grounds, there could be a ground strap on left hand side of engine to frame, don't remember if this was on a Cummins or Iveco, there are trouble some, they have a stud welded to frame, there is a updated strap, strap is long enough, there is a hole in frame, I clean paint off frame rail and ground to rail, Scott.
1 - 2 of 2 Posts
