Having issues all of a sudden with my 375 stx tractor throttle all the way down and then min throttle appears on my screen and arm codes are 01109 and 00019. What I've done so far is change the potentiometer on the hand throttle and shook wires when tractor was acting normal. When I shut tractor of most it act the way it should.
Discussion Starter · #2 ·
Also on 2 instances I was seeding along and it started to idle down but idled back up without shut it on and of
More than likely it will be the armrest controller is bad or going bad
Seem that most of the STX/TJ have been replaced around here.
One dealer was even stocking a rebuilt one
Well my the codes all say lost communication with armrest controller but I guess it could also be wired going to controller
Yes, could be. Check where they come up behind seat and then where the arm rest pivots.
Good luck
Tried playing with wires at those places when tractor was acting normal but couldn't get it to do anything
Tried changing hand throttle potentiometer didn't help. Changed terminators behind a post and on engine same results. Landed up changing armrest controller and seems to have been the problem.
