Im mounting some FM Radio's and this STX 375 has no gps cabling or bracket for antenna on top of cab
So.....i have a black piece of metal with double sticky tape and im putting that up top then running the cable into the cab and will run it under the mat and up to the lightbar.
I figured i'll try to hide the power cable the best i can
not sure where i'll mount the gps reciever....
I do have a Antenna/Reciever Combo but id need a different cable to go from the light bar to it..
not sure if i can order that or what to do..
I wish they would incorporate a lil thing called BLUETOOTH LOL
and go wireless with all of this stuff
sure would be handy
anyone have any helpful ideas or pic's
of how they did there machines
thanks
I have an 05 STX and it was pre- wired for an FM Radio.. the only thing you need to do is pull the fabric off the back right hand corner post and the wire for ur FM radio should be there.. and if u wnat the antenna on the roof you will have to lift up the roof and drill a hole in it.. but all the hard wear should be there... dont know if that helps you much or not
Discussion Starter #3
its going to be a Trimble (without the lcd screen)
and then its a trimble antenna/reciever combo antenna that came with our 2005 2388
i couldn't tell you what model
im guessing i just need a long cable to go from the antenna to the light bar....
the plugin to the antenna isn't like a coaxil..
its exactly like what used to plug into the old recievers
im guessing that shouldn't be to hard will it?
