1 - 2 of 2 Posts
Is anyone using drain tile to pump water back in the field later in the year? It would be nice to control drainage in spring which is currently our bigger issue, then if needed re water things later. Was thinking of building holding ponds and or be bearming up some existing sloughs for added capacity. Sure doesn't look as efficient as a pivot but would be quite a bit cheaper, we don't have anything tiled now so a guy could design it with irrigation in mind. Any thoughts?
1 - 2 of 2 Posts
