I run Luke pans, they work nice most of the time. If the flowers were planted with a drill, you can go any direction and you won't notice a difference. If you planted them in rows (I plant mine in 30 inch rows) then you will lose less by harvesting with the rows as long as the pan spacing matches the rows. (I have 12 inch pans so I actually use every other space to get 30 inch rows). You can cut against the grain ok, but when the heads of the flowers shake and rub against each other you lose seed, and there are the heads that hit straight at the point and they often go down in front. good luck
