I ask for help. We have Lexion 760TT installed sunnybrook cylinder.
I can’t choose bars on the cylinder.
How long will work BARON bars last?
Who replaced respond?
Pretty sure my Sunnybrook cylinder has boron treated rasp bars. After almost 900 separator hours they are in excellent condition. Under similar conditions a regular set of Claas bars will be wore out at around 1600 hours. I would get the boronized bars.
If you are in rocks the boron is not hard and the bars will get beat up pretty bad. When they boronize all the heat treat or hardness is taken out of the metal. I wish they offered heat treated hardened bars. If you do not have rocks or do not cut on the ground a lot then the boron should work well and wear longer than normal ones.
