1 - 11 of 11 Posts
I bought a t9.560 for next year. Mostly because I got it for the same price as they were going for at auction, but from my dealer.
One thing to be aware of is the t9.505 is only 450 hp. The stx 500 is 500hp. You would need to go to the 560 to be comparable in horsepower. Also, the NH is narrow frame up to the 560. The 615 and up are wide frames. The case is wide frame at 500 and up.
The T9 505 and CIH 450 are the same tractor.
So much so that NTTL test is not just similar, it is thee same tractor.
Don't bother reading both, performance specs are identical, just pick your favorite color.
Not that that makes any difference in this case. First one happens to be a Case, ok fine, Steiger.
http://tractortestlab.unl.edu/c/doc...b-4291-a149-97008700f9b4&groupId=4805395&.pdf
http://tractortestlab.unl.edu/c/doc...0-4c08-b494-711bf2650ce5&groupId=4805395&.pdf
1 - 11 of 11 Posts
