I'd mentioned earlier on the forum that I would like to get my land cleaned up of numerous potholes/sloughs and thought the Vwing ditcher might have been the way to go, but general consensus was that a pull scraper and pull dozer would be better suited to my needs.
http://www.thecombineforum.com/forums/19-planting-tillage/158250-pulldozer-v-wing-ditcher.html
So now I'm looking for this tag team combo to allow me to get the land straightened out. I farm in Southwest Sask where land is rolling and topsoil is at a premium. There is no bush, just potholes/sloughs that are farmable on the dry years and under water when its wet.
So in looking for a scraper what make/size is good for a farm application? What do you look for on a used scraper when you are considering buying it? What are the weak points? The ones I'm seeing are all cable to hydraulic conversions. Cat 463, 60, 70, and 80's seem to be mostly whats for sale. Are you guys that have done scraper work on your farm eyeballing it, using transit, using laser, or using GPS? Does anybody wish they would have just hired out the scraper work to a couple ukes and done the finish work with a pulldozer or is it best to do it all yourself? Where did you buy your scraper? Anybody deal with Quick Drain Sales out of Humbolt?
As for the pull dozer component; I know the one for Bridgeview is the granddaddy of them all but it is also twice the cost of something like a Landmaster. Is it necessary to have such a heavy monster when you the scraper to do all the tough cutting? Anybody have a Landmaster (or other non Bridgeview) and was it built well enough/been heavy enough for your application?
I think what we are trying to achieve is more filling than draining of these low spots. I'm assuming you want to strip the top 8-10'' back with the pull dozer on the high and low points, then use the scraper to move the high point to the low point, then use pull dozer to pull topsoil back over these spots and finish everything off so it farmable again. I assume these low spots will have a lot of good growing soil to a greater depth so maybe take more from them to move to the hill top as well?
Any experience/info is always appreciated. Thanks.
