This is not a rant, complaint nor question about repair. Sorry.
But my new to me 3450 cart, tbh model, vr controlled without blockage, so far has been I think the most impressive machine as far as accuracy I have ever had the pleasure to operate. I know that someday something electrical will glitch and I will feel the opposite, but my first impression now after putting a couple hundred acres thru it is awesome.
I took the time to properly calibrate 2 of the 3 tanks and ran the meters as long as I could to collect as many targets as possible. Weighed the bags with the product and entered the info into the monitor.
On the 3rd tank, I did not have the actual product yet that I were to use and I would not have it until the rig was in the field. SO I made a calculator call based on the supposed density compared to the known density of one of the products in the other tanks. I had to make a small adjustment on that one. But the other 2 products were spot on at .002% of the target rate I input into the monitor.
And those tank level monitors?.............OMG is that ever cool and so accurate. When the last bar falls out of the gauge, you have about 20' to go and the lines are empty.
I dont know if case has screwed things up like they always do when they aquire a good product, but my 3450 Flexi coil has really impressed me.
Thanks Flexi coil.
Thanks Flexi coil.
