1 - 14 of 14 Posts
The environment-friendly shale shaker is the first grade of solids control equipment in drilling purification system. And the environment friendly shale shaker can remove cuttings above 75μm brought from the drilling well to leave the liquid with smaller particles into the tanks below, which will flow into next grade solids control equipment to be treated.
The environment friendly shale shaker has its unique advantages as following: 1. G-forces linear motion up to 7.4 G (adjustable depending on the situation)
2. Hi-speed conveyance of cuttings
3. Higher processing capacity
4. Able to process heavier solids loads
5. Enhances cuttings processing volume
6. AWD device is adjustable from -1°~5°
7. Single side screens tension system to easily change the screens
8. Shale shaker feeder can be weir feeder or box feeder
9. Hook-strip screens can be PMD and PWP screens.
Recently the most famous environment-friendly shale shaker was designed by KOSUN, who is named the China solids control leader for drilling industry. Their products (mud cleaner, desilter, vacuum degasser, oilfield drilling decanter centrifuge, mud tank etc.), including shale shakers are wild used in solids control system for drilling industry. This enterprise is aim to designing and producing the environment-friendly and economical & practical economy solids control products.
As a Customers utmost manufacture, KOSUN welcome you all to communicate with us for the technical and service about our environment-friendly shale shaker and other solids control& drilling waste management products.
Discussion Starter · #2 ·
What’s the Decanter Centrifuge function in modern drilling?
As we all known, the decanter centrifuge is used in separating suspension of solid phase with particle diameter d≥2μm for drilling mud and fluids handling. Ruggedly built for oilfield and industrial services, it is especially effective in environmentally sensitive areas. It delivers high fluid-recovery rates and efficient solids control to significantly reduce the costs of makeup fluids and disposal. The centrifuge is precision –balanced for smooth operation over long periods at speeds of 0 to 3900 RPM, generating centrifugal forces up to 3000G’s.
So what are the Technical Features of solids controlling decanter centrifuge?
1. Innovative design includes longer bowl for increased retention time, resulting in drier solids and finer cut points
2. Big bowl Big Volume, high G force available
3. Stainless steel bowl, scroll, compartment and cover resist corrosion and provide long service life.
4. Tungsten carbide scroll points with wide spacing flights at tapered end create a finer layer of conveyed solids for consistent, uniform separation and maximum solids control efficiency.
5. Screw pump & Centrifugal pump feeding pump option available to meet different application
Therefore we need to choose the decanter centrifuge with the advantages above for solids control in modern drilling. And speaking the solids control, we have to mention one manufacture KOSUN. This company has 22 years history focusing on solids control and waste management products and servicing. The main products are liner shale shaker, balanced elliptical motion shaker, Shale shaker screen, desander, desilter, vacuum degasser, centrifugal pump, submersible slurry pump, shear pump, mud agitator, mud gun, drilling fluid mud cleaner, decanter centrifuge, jet mud mixer, Mud tank, Diesel tank, Water tank, etc.
Since now KOSUN was established long-term business relationships with several famous drilling projects and cooperated with some powerful partners all over the world, such as Gazprom,CNPC, SINOPEC, SOCAR, RG etc. Therefore we believe that the future drilling industry will develop to modern style base on some promising enterprises like KOSUN.
1 - 14 of 14 Posts
