1 - 20 of 114 Posts
[ A long, long post so I hope it arouses your interest.]
"The push button Combine" or in my home country of Australia, "The push button Header".
A term I first heard used over 30 years ago in the latter half of the 1970's when we took an L2 contract harvesting up into central New South Wales on the then fringes of the Outback.
The locals of that area were some very phlegmatic and very tough guys. They had to be to make a go of it in that area and they did their farming and grain growing in some very harsh country.
Completely different now with a lot of money and a lot of very sophisticated irrigation from underground water which was only just starting to be exploited when we first went up there.
In those days of old, they were still driving 711 Inters and MF 585's when we arrived with the L2 which blew everybody away and promptly got dubbed the The Push Button Header.
In fact they claimed that the old Inter 711's and MF 585's lasted about 4 or 5 years out there in that abrasive red soil and then they drove them into the nearest creek.
After a couple of decades they claimed they could use the stack of old combines as a bridge when it got wet and the creeks flooded.
[ We drove the L2 some 600 kms up there with a the front [ header ] on it's trailer hitched on the back and a fuel tank trailing along at the tail end.
Some 17 and half hours of near non stop driving in one day usually on one's own.
One polizia moved us right along out of his town.
We discovered later that he owned two combines for contract harvesting and no contractor was going to get a foothold on his patch!]
The generations of Gleaners that followed all used the same type of "electronics" or more accurately they used automotive industry based electrical monitoring systems which had been long sorted out by the automotive and heavy vechile industry over many decades.
As a result the Gleaner electrical control and monitoring systems are quite trouble free, ie; these systems have proven to be very robust and trouble free right through the life of the combine.
I have touched on [ and gone completely off topic ] the current trend towards electronically controlled combine operating systems in the Two Rotors thread.
So to bring this subject on the future electronic operating and control systems that will be a critical component of every machine that we will purchase and operate within the next decade, I have started this thread to allow discussion on this fundamental change in the way that our machines of the future will be operated.
Perhaps my age is showing but I am deeply sceptical about the long term reliability and the survivability in the dusty and vibration ridden conditions, typical of agriculture, of the consumer type electronics that the manufacturers are using in their newest range of combines and tractors.
There is no doubt that electronics can be made very reliable and can be made to stand up to some very tough conditions.
To have this type of electronic systems the manufacturers would have to move to the specialised military hardened electronic systems and that would make combines and tractors equipped with these hardened systems just about unaffordable to all except to the the most avaricious big bank CEO's and their incompetent minions.
The other options for the manufacturers are to provide fan and AC cooled, filtered air in sealed, pressurised, vibration isolated boxes or units with all the electronic control boards combined to just one easily accessible location.
A couple of manufacturers are moving in this direction but as anybody who has messed with the now rather primitive automotive based alarm and monitoring systems in a combine or tractor will know, even the best sealing still seems to allow a buildup of dust, fluff, moisture and general detritus on the circuit boards.
This buildup is a function of the electric fields that surround any circuit board and IC's and is usually he cause of or leads to faulty operation.
Electronics can be a truly marvelous means of creating great flexibility and extremely good performance from engines and complex machines such as the modern tractors and combines and the ability of the electronic systems to contribute to even better performance in the future is almost unlimited.
But the achilles heel of all current combine and tractor electronic systems is that just one single, tiny component on that circuit board needs to fail or even only partially or intermittently fail, the worst scenario, and the entire operations of that machine will grind to a stuttering halt.
Software from the manufacturers are another real problem which will get a lot worse as more and more electronically controlled systems are incorporated into the new combines and tractors.
By electronic standards the production run of a particular circuit board and the IC components that are specific to one make and even more likely, one model with variations of that model, are absolutely miniscule and wouldn't even match the preproduction, verification run numbers in consumer electronics.
Every time a board configuration is changed or the engineers change the specifications for some obscure reason, the software writers, the coders have to revamp the soft ware program for that board and the operation/s it controls.
There simply is not enough time or experience to thoroughly debug each and every circuit board operating program each time the circuit is reconfigured or the operation it controls is changed in some way, all due to the very low production numbers of that circuit and that soft ware program so bugs and some big bugs at that will happen on a very regular basis.
So now we have a consumer based , somewhat brittle in operation circuit board, an extremely low production run of circuit boards, a very small and generally short production run software /program which may be full of bugs and in all probability a growing shortage of competent software engineers who are familiar with the needs and nuances of the agricultural industries.
Now toss in some dozen or so models of combines plus an equal number of tractor models from each manufacturer and multiply this lot by the number of major agricultural machinery manufacturers and then the number of circuit boards and the necessary software in each combine / tractor [ 14 such circuit boards in one model of one make of tractor. Make shall remain nameless except it is painted green and yellow! ]
In this case, the number of circuit boards AND the accompanying entrails of the loom were changed three times in the one model and the only way of identifying the changes was by the serial numbers.
There is much, much more to discuss on the good and bad points of the electronic revolution that is just now starting to hit the actual operating regimes of the ag machinery.
I have mentioned the wrecking of a mechanically sound European combine as it's $30,000 critical circuit board blew up twice in quick succession.
Today I was told of a combine where it took ten days to just get it out of the shed to start this year's harvest.
The owner drove it into the shed at he end of last harvest and it was a late model in excellent mechanical condition when he did so.
Nothing he or the agents did or could find out could get that combine engine started when it was required for this year's harvest.
Ten days and a new circuit board [ none available in Australia. Availability of the huge multiples of circuit boards and even more software programs being one of main points I am making when looking into the future a decade or two ahead.] ] flown in from the USA and they got it out of the shed.
Now this can and will happen to any combine or tractor make so no names but the colour was that grassy green colour with the ripe grass colour to accompany it.
I have posted comments in the Two Rotor thread and judging from the number of views , many of you must have read some of that thread but at the risk of boring you, I will take the liberty of reposting my comments from that thread into here as the comments are more appropriate here in this thread.
Reposted from the Two Rotor Thread ;
One of the what I believe will be the really big problems downstream for the present and future generations of combines and will impact on their long term reliability, usability and resale value is that the current generation of games kiddy designers are incorporating more and more computer controlled functions into the combines, tractors and other complex machinery.
Without these boards, the machine or some part of it becomes inoperable and everything grinds to halt.
Nor have these computers and boards shown themselves to be particularly robust or reliable in Ag use plus software issues often arise as well.
Changes in electronics and software are moving at a continuing and quite phenomenal rate and the games kiddy designers are constantly changing both the computers boards, the number of computer boards in a machine and the software, always claiming to be supposedly "improving" the performance of the machine.
In say 15 years time a lot of computers and boards in the current generation combines and tractors will simply no longer be available and the electronics in 15 years may be unrecognisable in any case compared to the current generation of electronics.
For the most popular brands and some of the most popular models in those brands, the small companies and backyarders will still possibly make up custom boards to keep the machines running but for most of the late generation, small production run models of computer reliant combines and tractors when a vital computer board, just one of a number in the machine, blows up, the only real alternative will be the wrecker's yard.
The cost of this will be horrendous to the farming community but we won't see this cost until years down the track and by then it will be far too late.
The machinery manufacturers are getting their money now.
We will pay much later as machines still in excellent mechanical condition will be regarded as scrap as the boards and software are obsolescent and if a critical board blows up, cannot be replaced and is no longer available and without those all essential computers the machines simply won't operate.
As an example, I believe that in one particular late generation model of a very popular brand of tractor there are three different versions using different computers and a different number of computer boards but the only way you can tell which version is which is from the serial numbers.
In combines, my info comes from one of the best Gleaner hotrodders here in Oz,
He was in a wrecker's yard and there was a very late model and very large capacity european manufactured combine still in very good mechanical condition being wrecked, to his astonishment.
The wrecker told him that a computer board had blown up in the combine and a replacement was some $30,000 AUD [ US $28,000 ].
The board was replaced and blew up again in a couple of weeks so the combine owner said thats it and the combine went to the wreckers.
Those are the sort of problems we are facing in the long term with the current and future generations of combines and tractors as they start to accumulate hours and time and as the games kiddy designers put more and more computer type controllers into Ag machinery.
rom I got out of the contract harvest game just at the right time as I was seeing more and more of the problems on new machines that you were talking about. Brand new combine sitting as the sensors said the rotors were not turning ( they were) so the machine would shut down, combines that would not lift engine revs above idle every now and then. Every brand has had these silly electrical problems although some seem worse than others, combines that were in perfect mechanical condition but the computer said nope. I know that life has good a lot more comfortable but maybe we have gone a little too far ahead at the expense of reliability.
The farm has two newer tractors of one colour, one has all the bells and whistles and the other is the chore tractor that is considered basic, no push button transmission or super dooper programable hydraulics. We know which one will be still earning it's keep in 20 years time already.
As a collector of antique farm machinery, some of which can still perform it original duties being over 100 years old. I find myself saying quite frequently "how will this thing be able to still run when it's 30 years old". Or on cars with all the plastic now how will anyone ever restore one of these. I went from a 1972 G hydro Gleaner to a A-75 in 2008. Still have the G and use her some every year. But I don't think you'll get the hours out of these new combines that the 72 G has on her.
When the L came out with the electric over hydraulics I couldn't understand why the need for a switch-wire-solenoid-hydraulic valve in place of lever-rod-valve setup. Does the same job and the older is also easier to work on. I now look into the fuse panel of the new combine and the thoughts of what could go wrong makes you ill. Some improvements are not improvements at all just bigger problems to come around the corner.
I agree with your post. What was wrong with the lever and belt system on old machines. How many hours have been wasted trying to track a broken wire chewed off by a mouse. Just because the engineers can invent something new does not mean it is has place on a piece of machinery. How much money does this add to the price of equipement. Think about the hours invested in inventing and testing some of these electronics. Take for example the self leveling sieves in some machines. I live in an area with rolling hills and understand the concept of overloading the sieves on one side when on a side hill. How many bushels are actually lost here though, it surely can't be enough to justify the cost of electronic self leveling sieves. I know there are places were self leveling sieves are a practical application, but it seems more and more dealers are simplying ordering new machines with all the bells and whistles whether people want them or not. I unfortunately am not one of these guys as I still run an R7 and 760 Massey. But what machinery will be available to someone like me 20 years down the road? Automobiles are already going down the road of getting 10 years out of them and then you just throw them away because its cheaper than fixing the electronic problems it has accumulated. I can't help but think if a company would build machines similar to the L gleaner and 8820 john deeres and simply make them bigger and more reliable at a much lower cost they would be onto something great. I know there is guys out there that can trade every couple years and they enjoy most of the new features there new machine comes with. Anything that goes wrong is covered by warrenty. But there is a whole lot more guys however who rely on running used equipement and doing there own mechanicing.
Doesn't necessarily take 10 years.
I have a GM pickup with quadrasteer.
The electronic controller for the quadrasteer failed, no part available less than
2 years after the last truck rolled off the line with quadrasteer.
Good points made here, makes one wonder about future electronic issues.
Don
Monse, I've been saying this for at least 20 years now; we simply need the option of "stripped-down, bare-bones" basic combines, regardless of size. While I do embrace technology, and even want to see the pinnacle of ag engineering, such as a "self-running" combine, I wholeheartedly admonish the call to build just basic, mechanically-controlled combines and tractors.
No one on here, could be more correct as to the sheer longevity of such machines. I can restore any old model from the late 1960's on back, along with some of the 1970's ones that were made without all the "push-button" controls. The 1970's was only a transitional decade, with the 1980's seeing more of the movement toward total EM controls. By 1989, there simply was no other options. All combine models had converted over to this, period.
The option for an all-mechanical, lever and linkage actuated system is a must.
Demand it.
Mechanical linkage, like electrical can only go so far. The size of the new machines in height and length probably means that linkage would jam (just like on the older smaller machines), vibration was a problem with linkage wearing out/breaking. One reason for changing from push/pull rods was rust, water, foreign material jamming the linkage. Another is you can only have so many levers in a cab - you can have twice, three times the number of buttons to lever ratio in a cab.
After saying all of this, do I think the electrical/electronic combine is a good thing? The ones in 1970 were a good thing. If the manufactures had stayed with that concept of electric/electronic where it was need and no more the combine of today would be a different bred of animal.
Ergonomics was the buzz word of cab design in the late '60's & '70's. Today's cab is about fashion, not true function. Spending 300K, or more, is forcing manufactures to add more useless fashion designing to justify the cost of the machine. Everyone of use expect that cab to be better then the last, but there isn't a cab on a combine today that's worth 300K, or more, so the technology and justification for that 300K, or more, has to be in the machine itself - ergo, the electronic combine and all the computers that can be stuffed onto the machine.
Nobody voted with their check book to stop the electronic combine. All of the really big farmers have so much pride in their new electronic combine and heads that this entire forum has post after post of the new combine. Except for the one person posting about their 8820 up and running every combine post is about an electronic combine. As long as everyone keeps paying for the electronic combine, companies will keep building electronic combines. Vote with your check book - most of you will not because you know you have a business to run and you can't take a chance on old equipment.
Can the electronic combine be sustained? How big will they become before they are too big to be economically useful? Nobody knows the answer. The engineers and manufactures are willing to spend your money to find out. Vote with your check book, demand more from the company by expecting less electronics and longevity of older systems. Everyone of you that owns a electronic combine are part of the problem, and you are part of the cure. It is up to you with the money to buy new that will give this industry direction, if you start using your money to demand more, and less.
Frankb, the idea for the basic, mechanical combines, IS for them to be rather small. We don't need tiny, plot-sized ones, but I'm thinking just in the sizes equivalent to the 4400, 6600 or even an L2-sized machine. Offer three sizes, made to order.
Of course, those who need a really big combine, have the acreage to support such, and don't mind paying for all the "bells and whistles" to go with it.
Rom that was an excellent post and it brings up a problem that I have been concerned about for several years. My combine is a 95 model R 62 which has been very reliable for over 3000 hours now but it is 15 years old and I would like to upgrade but I am very hesitant to do so because of the very problem you have described. Any high school kid with a basic understanding of mechanics can fix any problem I have ever had with my combine but that is not the case with the new machines ! I can match the new machines capacity Bu for Bu and do it on less fuel per acre so where is the incentive to trade up ?
Who the heck is Frankb? My handle is frantbk!
What you are thinking and what the originator of this post is writing about seems to be two different subjects. The L2 was the second generation of the 1st electrical combines by Gleaner. Gleaner was one of the 1st to move away from the linkage system because the size of the combines were reaching a point of problem for the linkage system.
What the originator of this post seems to be talking about (in my view) is that the electronic combine is unsustainable. good equipment is being junk in Australia because of the electronics. Because Australia is a point farthest from the manufacture they are really on the cusp of a problem coming to all of Agriculture. The current business model for combine design is the trickle-down pyramid.
The trickle-down pyramid simply put is: The big farmer buys the machine new. They run it for 2-to-4 years. The big farmer trade it in for a new machine.
The trade machine is then moved down the pyramid to the next farmer who runs the machine for 2--to-4 years then trades it in. The machine is then sold to the next person in the pyramid who then runs the machine for 2-to-10 years. at this point the is somewhere around 18-20 years old.
At this point the people buying the machine are at the lowest point in the pyramid and run the combine until it is scraped, or they retire from farming.
This system has been in place since the mid-'90's when manufactures stopped building machines in the Gleaner L/8820-class.
What the originator is staying about the electronic combine is that because of the current disinterest from the manufacture these combines will not, and are not making it to the third and fourth level of the pyramid system. Basically due to the high usage of computer/electronic equipment needed to run them.
Because of this it is just a matter of time when their investment has no trade in value because only big farmers can afford the new combine, and once used, and aged from work. The combine's need for electric and electronic replacement exceeds the value of the trade in value of the combine. Simply put. NO ONE wants them because they CAN'T AFFORD TO FIX THE d**n THING BECAUSE OF REPLACEMENT COST.
Have I missed anything? I surely don't want to be the dumb guy in the room.
Actually Frantbk, there are the two ways of looking at this. They rather line up with each other, accordingly, too.
Rom talks about all the modern, high-tech trend in today's combine's, beginning with the L2, a merely improved Model L, in essence. He made some very good points.
Monse came in, speaking of the need for simpler combines. I agree, stating how I have been such the advocate since at least 1989. I comment on just how such combines will be devoid of all the EM stuff.
Your first post was not off in any way. You added that my idea could not work on our really big combines. I concur. My second post [directed more toward you with the typo] was how my idea excludes those big combines.
Back to the issue of the current trend in current combines. You have not missed anything that I know of. We clearly stand at the crossroads. It's time to split off again, and go two dedicated directions here. Your last sentence hit the nail on the head. Rom's own shocking eyewitness account of the Euro combine's untimely death, should be our wake-up call.
Discussion Starter · #13 ·
As in most things, my thinking on the future of electronic and computer controlled combines [ & tractors ] is still evolving and the many facets of this new phase in agricultural machinery will be explored by others as well.
So far in computer controlled combines we have;
1 / The increasing use of dedicated circuit board and IC controlled critical functions in the new generation of combines and tractors.
2 / The use of consumer standard components and circuit boards for the controlling functions and the consequent low reliability due to the harsh conditions, ie; vibration, dust, moisture and heat under which the circuit boards operate and for which the consumer type electronics were never designed.
3 / The miniscule, by consumer electronic standards, numbers of any one configuration of a board and therefore the very real problems of ensuring that replacement circuit boards will be available some years and decades into the future.
Without these replacement critical function controlling circuits and boards the machines will become just so much scrap iron.
4 / Due to the constant, frequent changes in the circuit board designs, the software designers and coders are not able to provide fully verified, quality operating programs nor has a fully developed debugging of the operating software been able to be performed due to the constant changes and the time constraints created by the constant changes.
5 / A shortage of competent software designers and coders with an understanding of the nuances of agriculture will probably become a serious problem as function controlling electronics are increasingly incorporated into new ag machinery.
There are other points as well but let me try and take another small look at the future of computer board controlled ag machinery.
The cost of the circuits and particularly the software will no doubt rise considerably as the software becomes ever more complex and the cost of the limited number of software designers and coders who are at all competent in this field will rise very substantially.
If we look at the consumer computer industry and the psychology that operates in that industry we will in all probability be looking at some company somewhere trying on a licensing system for the software in your combine or tractor.
You will be required to pay a license fee of a few dollars to a few hundred dollars annually to get the code to enable you to start and operate your combine or tractor for a given time until the software again times out.
Somebody, somewhere will inevitably try that one or in other words like all the current consumer computer software you won't own the software but will just be licensed to use it.
The companies will of course claim that this enables them to update and improve your combine's / tractor performance but at what cost to your personal freedoms and privacy.
Furthermore this licensing system really starts to break down when the combine / tractor changes ownership.
And what happens when a company decides, as do all consumer computer companies, decides it will no longer support a particular software program due to the age of the program, money problems or they are bought out by a competitor who just wants less competition for it's own products.
To take the future a step further; With the communications revolution well under way and an almost universal telecommunication coverage of a lot of the well settled regions in the western world, the combine's / tractor's computer controlled functions will be directly linked to the company's system allowing them to make changes to the software when you switch on or to report back and correct bugs, maybe.
This of course will enable the company to also build up a very comprehensive profile on both the overall and full operating regimes of that model of combine or tractor and in particular, an individual's profile of the way in which he / she uses that combine and the service profile and levels of service that owner actually gives to that machine.
A poor service record by you may just mean that the company jacks the costs up for your service requirements or in extreme cases, refuses to provide any extra service as the cost of what they will maintain is a poorly maintained combine / tractor will be too high in the companies consideration.
Of course this also means that you will get reminders almost constantly to service the various machines like an oil drain is overdue and we will shut you down in ten hours unless that service is completed.
Perhaps this will never happen but it is a fact of life in some of the computer industry and that is where the electronics and soft ware designers come from and that is the psychology they have been indoctrinated with.
Bears some thinking about and the trucking industry already has indications of that scenario arising.
The engine companies act as though the engine is still theirs and refuse to release the codes and programs for the engines and kick up an almighty stink when an engine operating profile is altered and they find that during a servicing.
I know of a case and the individual truck owner where exactly this happened until some very strong words from the truck owner to the engine company's senior service tech along the lines of just who in the **** owns this truck and it is none of your [ unprintable ] bloody business with what I do with my bloody truck so just get to work and shut up!
The above may some indicator on what is to come in electronically controlled ag machinery in the future as well.
One of the major problems with the swing to the electronically controlled ag machinery is the fact that nearly all of the senior decision making company staff and executives will have very little knowledge of the way in which the electronics industry works and in particular, thinks.
The electronic engineers and software designers are indoctrinated right through their training with the psychology of expecting constant change and much fiddling and the need to be different to make an impact with the public so the electronic engineers that move into the ag electronic industry just keep right on with that constant change psychology to our detriment.
Unfortunately I suspect that as yet, due to the relative newness of the ag electronic / computer controlled machinery, there are not yet senior electronic engineers in positions of influence in most companies that have the knowledge to both call a halt to the constant change by their electronics' engineering departments and to force a consolidation of the circuitry and software to provide reliability and long term continuity to a company's computer and electronic controllers in that company's ag machinery.
The electronic engineers just bluff the senior staff and convince them that all these changes are "advancements" and "performance improvers".
Besides it gives the electronic engineers lots of kudos and elevates their standing and income levels in the company if they convince, through ignorance, the senior management that their contribution is vital to the company's future in the ag machinery manufacturing business.
There is a lot of pain for both the companies and in particular their customers to go through before this whole new electronically controlled ag machinery development is fully sorted out and many may fall by the wayside before it is all settled.
What kind of wake-up call? I see an opportunity with the scraping of this machine. An opportunity to take a machine still in the prime of its service life and use it as a test-bed for a simplified combine. If Rom has any extra cash He could talk with the scrap yard and let it be know that the next time they have an electronic lemon (el) to let him know and bid on it at scrap prices.
The failure here is that everyone of you are under the impression that the computer system is need to run all of the machinery. As it is from the original equipment manufacture (oem) you need the computer system to run that machine. What you seem to forget is that what is running the combine is a network data management system turning on/off the combine. You don't need that to run the machine itself. The machine will run without the network data management system if you put a different electrical system in its place.
The next question is do you understand what I'm saying?
Yes I do, Frantbk.
I could not agree with you more on the issue of stripping-down and modifying that poor Lexion before utterly putting her down. When I said "wake-up call," I meant how shocking it is to see some half a million dollars worth of combine harvester go "up in smoke" all due to "brain death." That simply could not happen with a mechanical combine.
By the way, to preserve the brevity of this thread, without going too far from ROM's and Monse's original points, please feel free to PM me, any time, for further elaboration.
Discussion Starter · #16 ·
Clarification required here!
I was not told the make or model nor have I guessed or tried to ascertain the make of that european combine that went to the wreckers due to the cost of the failed circuit boards.
There are a couple of makes of European manufactured combines sold here in Australia but which make it was I do not know and I was not told!
I used that example of the extremes that we as customers will be looking at as the move towards electronics as the main of controllers of ag machinery comes into general use.
Nor do I know the actual age of the machine.
An important point as there have been a number of changes in names and affiliations in the last decade with the international ag machinery corporations buying, selling and using co-production so the obsolescence of the machine due to corporate changes, even though it may possibly have been only of a relatively recent vintage, may have been a factor although a factor that we should note well.
The real question about the death of this combine has more to do with the quality of the service department.
First we don't know if the motherboards were bad from the Original Equipment Manufacture (OEM). If the motherboards are bad then that is an issue of quality from the OEM.
Second, if the motherboards are not bad to to OEM quality. Then there was a problem with the voltage regulators which was allowing the motherboards to be spiked. If that was the case then it doesn't matter how many motherboards are replaced, all motherboards would be blown because of the bad voltage regulators.
Third, if the voltage regulators are not bad, then the wiring harness, generators are damaged causing voltage spikes that over power the voltage regulators and is spiking the system.
When motherboards blow, you don't just replace them and fire-up the system. You have to know what caused the system to blow. the question never asked, or answered is what is the quality of the service department? Do they just slap new motherboards in? If so then it would not matter because the end result is the same. The problem was never fixed before the new motherboards were installed.
The computer industry has the tendency to push everything to the lowest common denominator. This is the same with service techs. Did this dealership have high trained techs, or do they have part slappers. Anyone can slap a new motherboard into these combines. Trouble-shooting the electrical/electronic problems and fixing them requires techs with high skills (and high pay). Most dealership are not willing to pay for that skill level from their techs.
With every manufacture jumping on the ISOBUS bandwagon it is cheaper to buy, and easier to implement common off-the-shelf systems. Voting with the check-book and talking with your dealership about your displeasure with the company direction can't hurt. If you embrace the electronic combine this is the new fact of life. Which means you will have to keep an eye on your dealerships tech department and their skill-sets.
Another factor at play here is the fact that interest rates are artificially low and labour costs are high. Therefore you cannot afford to fix a broken down machine. Thus you have roll programs and therefore manufacturers need only to cater to the original purchaser for 2-3 yrs. When interest rates rise and labour costs fall, it will be mandatory to keep equipment going longer therefore there will be less gee whiz technology and more sticking with the tried and proven.
1 - 20 of 114 Posts
