So here is the go! I'm 20 year old here in Qld Australia on the family farm and been thinking about getting a good little combine to do our own work plus few neighbours crops. Got a few details that the owner sent through. Any thoughts or suggestions would be great thanks.
1981 international 1480
6249 eng hrs,
150hrs on new:
-motor
-hydro pump
-hydraulic pump
-front tyres
0hrs on new:
-pto shaft, seals & bearing
-seperator clutch
-engine mounts
Hydro motor ok
Transmission ok
Lh final drive needs new seal
Air con not working
Needs new cab apulstory
May need new live axel couplers in the next few hundred hrs ($30 x4)
Rotor box ok
Feeder box ok
Unload auger boxes ok
Need new elevator drive chain in next few hundred hrs (2 lengths of rs50)
Rear tyres need replacing in a few seasons
All other belts and chains look reasonable.
There are 2 oil leaks on it we will be fixing and it has $500 new hyd hoses on it.
Comes with a set of concaves and paddock ready.
Comes with 30' 810 rigid auger front w/pickup reel.
Sorghurm fingers, sunny trays & trailer come with.
Floor of the front needs re-sheeting and the reel needs attention, but it can & will harvest as is.
$18000+the jesus with front and trailer, paddock ready
6249 eng hrs,
150hrs on new:
-motor
-hydro pump
-hydraulic pump
-front tyres
0hrs on new:
-seperator clutch
-engine mounts
Hydro motor ok
Transmission ok
Air con not working
Rotor box ok
Feeder box ok
