finished a 1/4 of oats and pulled into a 1/4 of canola and went to change concave clearance and discovered it was at 45 (right to the bottom of clearance) and would not tighten. Found the two LITTLE shear pins that hold the plates together for moving the concaves were sheared and having a heck of a time getting it back together. Give me your opinions on A: how much less of a threshing job or losses would I have encountered with this setting and B: is this not a flimsy setup by Deere which also gives no warning unless your checking your clearance consistently (I am aware that the shear pins breaking causes me less headaches in the grand scheme of things)
