1 - 1 of 1 Posts
Does anyone know what the standard setting for the feeder house tilt would be for a r52 with 30 x 32 tires. I am sure mine was tilted for the corn head. The issue I have is when I use the grainhead, the stabilizer for the cutter bar rubs on the ground. The cutterbar is tilted up, while this jumps over stones great, it doesn't cut quite as close as it should. I understand the newer one don't even have a adjustment on the feederhouse. So, what is the setting that equals where the newer ones are set at? Thanks.
1 - 1 of 1 Posts
