41 - 45 of 45 Posts
I think your big gain could be the headers if you are not running newer flex headers. A 40ft macdon will work any class 8 combine in any crop if you are willing to go the speed it lets you. But i think all the new flexes make the old ones look bad.
X2 Even, smooth feeding is the #1 difference to thruput on any combine. I've seen the same combine go from 1.5 --> 4.5 mph, same crop, same day, same size heads....one rusty and with a rounded off cross auger, the other shiny, sharp edges on the auger, and full finger. His broke, so he borrowed mine.... Obviously drapers can be even better.
Hey MTfarmer what way did the deal go. Although impracticable it would have been a good comparison to get 1 of the other for a proper evaluation.
In the late 70’s with a NH TR70 in swathed barley you could achieve that simply (sorta) by turning the feeder chain around, it was close to the difference between running and not running it was so ******* frustrating!:52:
In typical big Corp fashion it took New Holland until 1990 to install the feeder chain properly.
Hard to beat a Massey rock trap system I think. The beater takes the hit, not the rotor and is easily dumped. I hated that stone trap on the Gleaner. It works good it was just PITA to climb up on our R62 with 2 wrenchs and dump. 2 feeder chains hitting the rocks wasn't always great either.
41 - 45 of 45 Posts
