Hi. I have recently bought am Tm115 with around 3000 hours. The other day when I tried to change gears A and C range did not work anymore... Tried to recalibrate the trans and it shows U87 error code. Can you give me some tips or what should I do? Thanks
Synchroniser is not in neutral. Check the synchroniser movement in HL. If the synchroniser is not in neutral, possible potentiometer and its linkage is faulty or a mechanical fault in the gearbox.
That is about as much as the workshop manual says.
