Tire Wheel Land vehicle Vehicle Plant
Tire Wheel Automotive tire Hood Tread
G’day all I’ve broken the 4 bolts on the swinging drawbar of my 4555 they’re all replaced and the front hanger is fixed but I’m just wondering what the torque specs are for the 4 bolts on the front hanger into the bottom of the transmission are and the 4 bolts onto the rear carrier.
TIA. Regards,
Luke
I used to pull a new holland 1063 bale wagon with Deere tractors like that and a support hitch had to be made up to hook on the 3pt hitch bracket above the pto (hyd valve is hooked on those bolts in photo) and then a metal support went down around the drawbar for more support.
Without the support expect repeated failure using heavy loads that wiggle up and down like the sprayer or grain cart.
As for torque specs on the bolts, deere puts a page in the back of every operators manual with bolt size and grade and then gives the corresponding torque needed.
