1 - 20 of 27 Posts
How tough can a guy harvest flax and not worry about it not coming out of the bin for a few days before it gets dryed. Not worried about drying it can go through dryer a couple times if I have too
Well if you are getting after it within a few days to dry, a point on moisture is probably ok. Wouldn't chance it past that.
We took flax off 12-14% last year, cool and it kept in the bin fine turning every few weeks. We didn’t dry it, found a buyer that was willing to blend it off with dry. Was told that drying flax can mess up the oil content. Do you have any experience drying flax? Would like to hear from someone with experience.
Discussion Starter #4
I believe I took it at 13 last year and was no problem drying. Gonna take a sample this afternoon just want to know how far I can push it. Looks like only today and tomorrow as far as the forecast goes
We have several times taken off flax up to around 13%. We dried it in air bins using a 100-125,000 btu diesel heater in front of the aeration fan and filling the bin half full. It takes around a week to dry it like is. The trick is to take out at least three feet of grain out of the bin around 2-3 days and 7 days after you start drying it. If you do not you will have a ring of rotten flax stuck to the wall of the bin where all the condensation runs down into. Flax is very difficult to blow air through.
Any advantage to swathing this time of year? In 2016 we finished straight cutting flax in November and the tough straw did a lot of damage to the combine. Was like putting tree branches through. Part of me says swathed will he worse because it won't dry out as well but then I wonder if the straw won't cure anyway and may rot a bit if swathed. Best case scenario is it will be laying 10 days before I get to combining flax while I finish other stuff, lots of green stems right now but good killing frost in forecast.
I can remember drying flax with a 500 bushel behlen batch drier and it wasn't good as the flax would come out of the louvers when filling or unloading making quite a mess on the ground . Had to have plywood down to catch it but if it was snowing or raining you would basically shut down . But can remember thrashing flax with snow on it and bubbles coming out of the screens but then had to go inside and scrape the gunk off after the batch . Won't doo that again EVER !!
I would swath it, then hope for a big wind storm, problem solved!
16 was a bad year for pasmo. It doesn't matter when you put it through the combine after it has been infected. It sounds like you are combining a rock pile and can do serious damage if you run the combine to capacity. Also hard on the fuel bill. I had previous experience with pasmo and hit it with fungicide at 10% flower in 16 for that reason. I (and the combine) could tell where the plane had missed a spot.
I already earned the merit badge for putting the brush grapple on FEL and picking flax out of any wind break and the neighbors field when swathed so dont need to live that scenario again. I couldn't say if 2016 was pasmo but good to be aware of that. The whole field whether hills or low spots came out the back as wads straight cutting. If it was disease that toughened the straw then that is something to remember for future observations. Think I will swath 30 acres or so just to see if there is a difference when I go to combine. Forecast has - 9 for a couple nights so that will kill what is there so swath a bit in a few days and see how much wind that brings to my area.
I remember doing flax one year and it would wrap on the stone trap beater so bad it was smoking . The only thing was to get under there and cut it out with a serrated knife . Well that didn't last too long and we had called in the huts with their JD's and they weren't having mush better luck . The only combine going was a old twin rotor yellow new Holland ( old yeller ) and he wasn't banging or nothing and the straw coming out wasn't all chewed up into cotton balls .
We grew 220 acres once!!!! f Asked a old guy how do you know when you can combine it .."Sonny he said,, don't worry it will let you know when it's ready",,,,we tried for weeks waiting and trying at 1-1.5 mph,,, then one warm afternoon, magic, it decided it was time..4.5 mph and away we went ..for 4hours then back to plugging and pulling out the friggen flax..In the end last off Nov 21th,,over a bale a straw a acre ,44 bushels ,,16 n% moisture and dried it all....Wife still swearing at the stuff..as she says Fukin Flax ..
Yes flax is the hardest commodity to deal with on a damp yr. The straw is unreal and that is why they make clothing out of it. Using this stuff to make tow ropes for stuck air drills would likely be a great idea as well. If you have deep erosion areas on slopes etc just mix dirt and flax straw together. Flax straw doesn't break down easy and will be there for yrs. Our R62 has it wrap on the outer part of the rear feeder chain drive. We have wrap shields between the sprockets and it does have a problem there. Just next to the bearings on either side there is a round pipe which bearings are tucked away in. It wraps and smokes into a black donut. Over the yrs I learned to just leave it be and keep going. Eventually it stops smouldering and just turns into an anti wrap shield itself. My dad on the other hand can't stand smoke coming from there and has to deal with it instantly. So he pokes and pulls at it letting the embers fall into the stone trap area making a real fire lol. Somehow when you keep going this never happens but stop and play with it and you have trouble. I remember 750MF and 760 MF days when every paddle was wrapped tight in the feeder house. Spent many hrs with a Sawzall cutting that crap out.
Forgot to add that the good part of flax for me with the straw, is heating my yard. Flax straw dry yields 8500 btu's/lb. Throw a round bale of that in my huge boiler and you have heat galore.
These type of falls are terrible for flax harvest especially if there is a lot of straw with the flax. Tough flax and tough long flax straw are dufficult to put through any machine. The old conventional like a 9600 are probably the best for getting it through.
1 - 20 of 27 Posts
