Tow between or tow behind? We use tow between no wheel tracks can use bin to spread urea , so tow behind is it better? Can you use your bin to spread urea?
Well, maybe.
Any demand?
Well, maybe.
Any demand?
That would be fun with castor wheels on the front of the cartSo filling a tow behind do you back the seeder up to truck?
Generally, you drive the truck to the seeder.So filling a tow behind do you back the seeder up to truck?
Thats the first time I've heard someone use all those examples. Do you have one of them tow behind tractors too that would also help outTow behind. I'd rather compact the humps between the seed furrows after the seed is in the ground, than the whole seedbed before the opener gets to it.
Same with moving equipment and trucks in the field. If there is a choice, they always get driven on seeded ground rather than the to-be-seeded ground.
Thats bazar when we were looking at flexicoil the tow between was $12,000 cheeper.On my quote bourgault tbt tanks cost more than tbh. Not sure how they can justify it.
I would if I could, but in the mean time I can run 8 psi in the tractor tires, the cart tires are 4X that. Soil compaction correlates to tire pressure.Thats the first time I've heard someone use all those examples. Do you have one of them tow behind tractors too that would also help out
