Hello again, new question. Does anyone know the location of the trans pressure sensor on a TR 95? Have followed lines from pump to motor and see nothing. The wiring diagram I have does not show either the light in the dash or a sensor. The light and buzzer are on but hydrostat works perfect and seem strong. Thanks
Newer TR's have a high temperature switch on the bottom of the hydraulic reservoir. I do not believe your machine has that switch or any other for temperature or pressure. Only switch I could find was on the the 3208 Cat for high temperature. There is a switch associated with the hydrostat inching pedal but that would not be a high pressure or temperature switch.
Discussion Starter #3
Thanks for responding, think I finally found it! It is on the back of the 4 speed manual trans, at least the light goes out when I unhook that wire anyway. Can’t think it’s sensing much pressure there, will look into it more later. Thanks again
I would ask your dealer tech about this. IDK anything about the TR95, but sounds real similar to my old JD 7720---there was a pressure sensor on the transmission for lube pressure. The tranny had a lube pump built in that circulated oil to the bearings and gears (only worked in forward, not reverse!) The fact that you can disconnect this and the light goes out eliminates wiring problems, so you are left with either the sensor is bad, or the lube pump is not working. I wouldn't run it until you are sure the transmission is getting lube pressure.
You are right. The early TR95 transmission does have an internal pump for oiling. Probably not good to drive without pressure. Pressure sender part number 272537 is NLA. It appears that JD part number AH76862 would also work as New Holland was buying transmissions from Deere for a time. This assumes that the sender is faulty and not the transmission pump.
Discussion Starter #6
Thanks, the knowledge/information on this site is amazing! On an almost 40 yr old machine to be able to come up with a cross reference part number is impressive. Very much appreciated. I will get a gauge on there and see what’s happening, won’t be for awhile, haying is the priority right now......if the rain will stay away.
