Have a TR 96, the monitor is showing the stone trap light is lit. The stone trap is fully closed. This is a electronic stone trap, not sure if that matters. Is the sensor bad that is mounted underneath on the door? Or do I have a different issue? Is there adjustment for that sensor? Thanks for the advice.
Jason
There is a mercury switch that tells if your trap is open or closed. The wiring attached to the switch can get old and cause a fault. The new switches on the market are a new type that don't use mercury, and are really crappy. See if your dealer can source you one of the old switches. They are used on various types of equipment, so they should be able to find one.
