1 - 2 of 2 Posts
Losing rotor speed on TR99, have to keep bumping it up every 15 min. I know the 97's and 98's had a rotor speed lockout kit to put on and prevent this from happening. I didn't find a kit number for the 99 so i'm assuming it comes with one from the factory, if this is true and it has one what would be worn out first to cause this if there are no external leaks, and where is this valve located, by the elevators like the 98 or is it on the valve block? Any help on fixing situation would be apprecieated
One of two things is happening. 1 You have might have a small hydrulic leak. The pistion in the hub maybe leaking or the line and fittings going to it. 2 the electric solinoide that is monted on the elevator. the valve in it maybe leaking pressure back.
1 - 2 of 2 Posts
