1 - 2 of 2 Posts
First check if you have power to the switch at the red/grey wire at one of the center terminals. If no power then check the circuit breakers in the engine compartment. If there is power, then switch on the lights and see if you have power to the dkbl/w and the dkgn/w wires on the end terminal. If no power then the switch is bad. That is the only common circuit between the bin/auger lights and the work lights.
1 - 2 of 2 Posts
