Is there a pressure relief on the pump getting weak. Can you hear a chatter in the pump? I had the same problem on a tractor, reset the relief spring and it solved it.
To heat up that fast the oil must be going over the relief valve. Maybe a function not returning to neutral. Something that may not be obvious like unload auger retract pedal stuck down. Probably should confirm the oil temp is high not a fault with the sensor or warning circuit.
if you have an "asn" 96 there is a little filter inline just before it hits the stack. 9614152 part #. shouldn't cause you issues but if it is plugged it will be an issue.
Discussion Starter #6
Found the filter was back by the motor listed lid in grain tank to get to it,about 2 inches long. Ordered a new one,hope that is the problem thx
