On my TR98 I have the reel speed dial and it has the manual and auto switch. The problem I had was when running on manual everyonce and a while it would speed up to max speed and you could not turn it back down, only switch it to off. It had to run like this for 5min or so and then it would settle back down. Any suggestions?
Mine was doing that this year too. I adjusted it manually on the valve and ran it. Next spring I'll have to take a real (or maybe a reel
) look at it. I'm suspect of the magical black box that is the reel speed controller.
The odd thing is that it would kick up into faster speed only when something else electronic was in use. Like the A/C clutch, the header lift or drop or the reel lift/drop. So mine is spiking the voltage for some reason, leading me to think that the box is gonzo.
