Has anyone ever had a problem getting enough oil flow to a set of Dual aftermarket chaff spreaders on a later TR? Reservoir is full up front, flow is turned up all the way, but i can't get them to spin as fast as i want unless i run the reel pretty slow. They spin great until you start moving and rob the oil for the reel. Is there anything you can do outside of using a bigger pump and more oil?
TR99 has a pair of lines back there, I think???
Need to plumb like a 98 where oil right from pump goes to a flow control and oil from spinners and bypassed oil feed back to reel control so it gets full oil flow after spinners. e-mail and will try to get some pics. Easier then to explain. [email protected]
That makes sense. Most of the 98's ive saw never had any problems, but most of them usually only had one spinner too. Compared to the duals which is nicer but aparently use a lot more oil.
