I have a new to me 2166 and 1020 20' head. The tracker always favors one side. If I unhook the centering pot it goes all the way the other way. It works fine in manual. We have ohmed all of the pots and they tested ok. we also tried switching them around and it did the same thing. We also tested all the wires for continuity to the switches in the console and they tested fine. also all the switches tested ok. and it didn't make any difference if we switched relays around either. any ideas am I missing something obvious? TIA Al
Discussion Starter #3
I tried switching the header height one with the centering one and the one on the right end of the head but it still acted the same. I also checked them with an ohm meter and they seemed to test OK.
Make sure you have done the header on calibration. Make sure the height cable is free and the sensor bar is moving freely, you cannot get a good calibration if hey are sticking
