1 - 1 of 1 Posts
Any one put these on a 2000 /1254 rogator ? Bought the weld on bracket for the quick attatchments to be bolted to . The picture for mounting shows a wheel motor housing that is pretty much 90 degrees to axle mine are at an angle and require some messing around to mount to get everything square with the world .When that's all done then the bracket hits the tire . Looks like solution is to make 4inch wider plate to move over . Just wondering if any one has run in to this also .Thanks for any info .
1 - 1 of 1 Posts
