I replaced the fuel filter and sediment bowl and capped the fuel pressure sensor and now I can't get the fuel system bled. If I remove the bleed screw on the fuel filter fuel flows from the tank, no air bubbles, so I think I have that. Then I try removing the bleed screw on the injection pump and start using the hand pump. It is really hard to pump, but after a while I get a little air then a tiny bit a fuel. I only get a very small amount of fuel and it is hard to tell if the hand pump is even doing anything. I tried putting that screw back in and cracking the injection lines and I get nothing at any of the injectors. I even tried cranking it with the bleed screw out of the injection pump and nothing came out.
I'm stumped. Should it be really difficult to use the hand pump, or is something wrong there? What do I do next? Any suggestions?
