i remember back some of you were discussing that your two- way was causing gremlins with your machines. im having the same problem now. when i key the mic it makes my greenstar go crazy and shuts the outback auto-steer off. anyone else had these particular problems??? what do i need to cure this? my radio is wired into the power strip under the console. do i need to run it directly to the battery or what??? at the present time im not running a gps on the yield monitor, so i dont think its interference from the antanea. its from the power----i think
