Hi I just bought New Holland 94C Straight cut Header basically honeybee SP30.
Better rate down point The combine is unable to lift the header it only goes down and the lateral tilt works.
the Header weight is 6283LBS.
Do you think this is the problem or is there a way to increase the hydraulic power? I only have two cylinders on the combine I know there was an I only have two cylinders on the combine I know there was an option three cylinders.
Do I need to add the third cylinder and if so does it just attach with longer pins?
Please help
Thanks
Please help
Thanks
